    查看: 1156|回复: 3 收起左侧
    [分享] 许愿墙X1.0   [复制链接]
    安装许愿墙需要安装JQ库
    1)升级数据库:
    1. CREATE TABLE  `zy_lovewall` (
    2. `uid` INT( 10 )
    3. NOT NULL ,
    4. `name` TEXT CHARACTER SET utf8 COLLATE utf8_general_ci
    5. NOT NULL ,
    6. `pid` INT( 10 )
    7. NOT NULL ,
    8. `message` TEXT CHARACTER SET utf8 COLLATE utf8_general_ci
    9. NOT NULL ,
    10. `x` INT( 3 )
    11. NOT NULL ,
    12. `y` INT( 3 )
    13. NOT NULL ,
    14. `paper` INT( 3 )
    15. NOT NULL ,
    16. `time` INT( 11 )
    17. NOT NULL
    18. ) ENGINE = MYISAM ;
    复制代码
    2)打开faq模板,在最上面添加:
    1. {subtemplate aa_zyhome_lovewall}
    复制代码
    3)新建模板,名称:
    1. aa_zyhome_lovewall
    复制代码
    内容:
    1. {eval $zyhome=$_GET['zyhome'];}
    2. <!--{if ($zyhome=="lovewall")}-->
    3. {eval $zyact=$_GET['zyact'];}
    4. <!--{if ($zyact=="ztpos")}-->
    5. {eval $x=$_GET['x'];}
    6. {eval $y=$_GET['y'];}
    7. {eval $pid=$_GET['pid'];}
    8. {eval $db->query("UPDATE zy_lovewall SET x=$x,y=$y WHERE pid=$pid");}
    9. {eval die;}
    10. <!--{/if}-->
    11. <!--{if ($zyact=="post")}-->
    12. <!--{if ($discuz_uid==0)}-->
    13. 未登录
    14. {eval die;}
    15. <!--{/if}-->
    16. {eval $paper=$_POST['paper'];}
    17. {eval $paper=$paper[0];}
    18. {eval $word=$_POST['word'];}
    19. <!--{if ($paper<0||$paper>5)}-->
    20. 纸条编号错误:{eval print_r($paper);}
    21. {eval die;}
    22. <!--{/if}-->
    23. <!--{if (strlen($word)>200)}-->
    24. 纸条过长
    25. {eval die;}
    26. <!--{/if}-->
    27. {eval $q2=$db->fetch_array($db->
    28. query("SELECT pid FROM zy_lovewall ORDER BY pid DESC LIMIT 1"));}
    29. {eval $q2=$q2["pid"]+1;}
    30. {eval $x=rand(0,100);}
    31. {eval $y=rand(0,100);}
    32. {eval $timestamp=$GLOBALS[timestamp];}
    33. {eval $db->query("INSERT INTO zy_lovewall VALUES
    34. ($discuz_uid,'$discuz_userss',$q2,'$word',$x,$y,$paper,$timestamp)");}
    35. 您许的愿望发表成功了
    36. {eval die;}
    37. <!--{/if}-->
    38.         {subtemplate header}
    39.         {eval require_once DISCUZ_ROOT.'./include/discuzcode.func.php';}
    40.                 <div id="zylw_mvcover"></div>
    41.         <div id="nav" style="width: 960px;"><a href="index.php">佳品水族社区</a> &raquo; 许愿墙</div>
    42.         <div id="wrap" class="wrap s_clear" style="width: 960px;">
    43.         <div class="main">
    44. <style>
    45. .alert_error {padding: 6px 0 6px 58px; line-height: 160%; background:url(images/default/right_big.gif) no-repeat 8px 50%; font-size: 14px; }
    46. </style>
    47.                 <div id="zylw_addwrap" class="content">
    48.                         <h2>请选择一张纸条样式</h2>
    49.                         <div id="zylw_zt_se">
    50.                                 <div class="zylw_paper zylw_bac_0" id="zylw_zt_se_current"></div>
    51.                                 <div class="zylw_paper zylw_bac_1"></div>
    52.                                 <div class="zylw_paper zylw_bac_2"></div>
    53.                                 <div class="zylw_paper zylw_bac_3"></div>
    54.                                 <div class="zylw_paper zylw_bac_4"></div>
    55.                                 <div class="zylw_paper zylw_bac_5"></div>
    56.                         </div>
    57.                         <h2 class="s_clear">输入你的愿望吧</h2>
    58.                         <div><textarea id="zylw_txt"></textarea>
    59. <span style="
    60.     float: right;
    61.     width: 330px;
    62.     margin-top: 4px;
    63.     font-size: 18px;
    64.     line-height: 30px;
    65. ">你想要给你的亲人、同学、朋友一个特殊的礼物吗?
    66. 那就给他一个个性化的许愿吧。完全免费的个性化许愿。</span>
    67. </div>
    68.                         <button class="zylw_fbxy">发布心愿</button>
    69.                 </div>
    70.                 <div id="zylw_main">
    71.                         {eval $q2=$db->query("SELECT * FROM zy_lovewall ORDER BY pid DESC");}
    72.                         {eval $zyhomeshow=Array();}
    73.                         {eval $i=0;}
    74.                         {eval while ($asdfgh=$db->fetch_array($q2)) $zyhomeshow[$i++] = $asdfgh;}
    75.                         <div id="zylw_main_in">
    76.                         {eval $zindex=200;}
    77.                         <!--{loop $zyhomeshow $thing}-->
    78.                                 <div class="zylw_paper zylw_bac_{echo $thing['paper'];}" id="zylw_p_
    79. {echo $thing['pid'];}" style="position:absolute;left:{echo $thing['x'];}%;top:
    80. {echo $thing['y'];}%;z-index:{echo $zindex--;}">
    81.                                         <div class="zylw_paper_hide"></div>
    82.                                         <div class="zylw_paper_word">
    83.                                                 <div class="zylw_paper_word_title">纸条编号:{echo $thing['pid'];}</div>
    84.                                                 <div class="zylw_paper_word_ava">
    85.                                                         <img src="uc_server/avatar.php?uid={echo $thing['uid'];}" /><br />
    86.                                                         <a href="space.php?uid={echo $thing['uid'];}">{echo $thing['name'];}</a>
    87.                                                 </div>
    88.                                                 <div class="zylw_paper_word_word">
    89.                                                         <!--{echo discuzcode(preg_replace("/\s?\[at\](.+?)\[\/at\]\s?/ies", "", $thing['message']), 0, 0, 0, 1, 1, 1, 0, 0, 0, 0, 0, 0);}-->
    90.                                                 </div>
    91.                                         </div>
    92.                                         <div class="zylw_paper_time">{echo date("Y-m-j H:i",$thing['time']);}</div>
    93.                                 </div>
    94.                         <!--{/loop}-->
    95.                         </div>
    96.                         <div class="zylw_add"></div>
    97.                 </div>
    98.         </div>
    99.         </div>
    100.         <script src="http://zyhome.66rt.com/templates/out/lovewall_x1.htm"></script>
    101.         {subtemplate footer}
    102.         {eval die;}
    103. <!--{/if}-->
    复制代码
    打开css_common模板,在最下面添加:
    注意:其中有很多图片需要上传到自己的论坛
    这里提供图片下载:
    附件下载信息lovewall.rar
    附件大小:58.89 KB
    附件售价:金钱 0 枚 [记录]
    下载次数:2
    更新时间:2021-4-5 12:43
    下载地址: 普通方式下载 - lovewall.rar
    安装完成后访问的地址是:
    1. http://你的论坛/faq.php?zyhome=lovewall
    复制代码
    2021-4-5 12:46
    2021-4-5 12:46
    2021-4-5 12:46
    2021-4-5 12:46
    2021-4-5 12:46
    2021-4-5 12:46
    2021-4-5 12:46
    2021-4-5 12:46
    2021-4-5 12:46
    2021-4-5 13:05
    2021-4-5 13:17
    伊如风
    访问时间:2023-08-03 15:02
    啊这
    访问时间:2021-07-28 20:24
    喀麦隆
    访问时间:2021-05-30 09:33
    访问时间:2021-05-25 12:06
    实中网
    访问时间:2021-05-03 21:42
    访问时间:2021-04-10 17:33
    提醒您: 您在"佳品水族社区"交流请遵守网络治安管理条例," 佳品水族 "发表的文章《许愿墙X1.0》版权归属作者所有,如是转贴版权归属原作者所有.本社区不对其真实性做任何考证.
    引用:
    看帖回帖那是一定要的:佳品水族社区网友:好贴......
    P.S.: 请用心回复主题,写出你自己的感受、而不要草草了事。回复是对LZ的最大支持!
    卡片说明:喀麦隆吟诗作对,赏花弄月,突然天边飞来4金币砸到了他的脸上。
    升级错误,MySQL 提示: Unknown collation: 'utf8_general_ciNOT' ,请返回。
    卡片说明:喀麦隆被苍老师看中,苍老师奖励了 4金币。
    引用:
    看帖回帖那是一定要的:打酱油路过,不关我的事!
    卡片说明:伊如风今天很不开心,身边的朋友突然拿出5金币把他给逗乐了。
